Results 1 to 3 of 3
Thread: Need some help with a T87
    Jun 2014
    Default Need some help with a T87
    I have a swap done, L86 and 8L90 in a 67 Camaro. I had to buy the ECM and TCM separately from the drivetrain because they were not included. The ECM works fine but the TCM is setting codes. From what I understand it either needs the correct VIN and or 8L90 program with the specific solenoid info on the side of the trans case. Can anyone help me out? The GM dealer is saying they won’t flash a used TCM.
    Which specific DTC codes is the TCM setting?
    Jun 2014
    which specific dtc codes is the tcm setting?
    p0700
    u0100
    u0101
  1. 8 Speed T87 compatibility
    By LS-SWAPPER in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 24th, 2019, 05:18 AM
  2. GM T87 TCM 8-speed
    By cooper1965 in forum General
    Last Post: January 13th, 2019, 12:27 PM
  3. T87 OS/flash compatibility
    By DURAtotheMAX in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 10th, 2017, 02:28 PM
  4. When the DVT will be available for T87 ?!
    By wesam in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 4th, 2016, 09:27 PM
  5. Problem with t87
    By 600+duramax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 22nd, 2016, 06:13 AM
