Results 1 to 4 of 4
Thread: LS1B ECM with manual transmission (NV4500)
    Jun 2021
    Default LS1B ECM with manual transmission (NV4500)
    Hi there,
    I am working on a a 4.8 liter with an LS1B ECM that came out of an auto that I have hooked up to a manual transmission. Is there a good place to get a base tune to convert this ECM over to a manual transmission tune? It wants to die when I push in the clutch when it is moving, which I feel like might be some issue with the automatic transmission tune.
    Thank you for any help with this, and let me know if I can provide any more useful information.
    Daniel
    Have to do a segment swap, just use a Camaro/Firebird or 02 Silverado file as your base file then segment swap the transmission and trans diagnostic segments over from a manual file. You'll need to update gear ratios/speedo/tire size over to match your transmission. You'll also need to know DBC vs DBW, if there are any platform specific things you're looking for, and how your PCM is currently wired as the different platforms have minor differences.
    Post your existing file up as well.
    Does the transmission have a Speed sensor?
    Also, is CPP (clutch pedal position) switch installed and working...?
  1. Looking for Ecotec 2.4L manual transmission tune
    By carcrafter22 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 20th, 2014, 05:42 PM
  2. Transmission Manual Mode
    By SkinnyPedal in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 7th, 2014, 12:29 PM
  3. Manual transmission temp PID
    By alwaysinboost in forum General
    Last Post: May 5th, 2013, 03:39 PM
  4. How to apply patch for manual transmission
    By Age08 in forum Gen III V8 Specific
    Last Post: March 6th, 2013, 03:19 PM
  5. Who can tune a Camaro V8 manual transmission for me ?
    By horst in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2010, 03:31 PM
