Results 1 to 2 of 2
Thread: MAF rescaling help
    Apr 2021
    Question MAF rescaling help
    I have a rpi 5
    May 2020
    On the RPI site is says this doesn't need to be rescaled , but its my understanding that you should see anywhere between 35-40 g/s at idle. So my suggestion would be to datalog your MAF rate and figure out the scaling factor you need to get it to read around 37g/s since you increased the size of the intake the velocity of the air is slower therefore the readings are probably lower so you would need to multiply the MAF scale by the scaling factor in order to get the correct readout. Before you do all this make sure the MAF is clean and that all the clamps are tight to ensure that the sensor is getting the correct readings. I'm sure someone will correct me if I am wrong, but this has worked for me in the past.
  1. ol maf tune or ve maf open loop and lambda question
    By 400ss in forum Gen III V8 Specific
    Last Post: February 1st, 2015, 07:12 AM
  2. E38 fan rescaling ?????
    By Y BE AVG in forum Custom Operating Systems
    Last Post: August 22nd, 2012, 04:19 AM
  3. rescaling map sensor
    By BAD BOB in forum FlashScan V2
    Last Post: May 16th, 2011, 02:42 PM
  4. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
Tags for this Thread
