Results 1 to 7 of 7
Thread: CM2200 2012 68RFE latest release base file
    Aug 2019
    Default CM2200 2012 68RFE latest release base file
    Would anyone happen to have the last released software version for 2012 CM2200 with 68RFE? Thank you, everyone.
    Aug 2019
    Thank you.
    Apr 2022
    Is this the same for the 2010 ECM
    Senior Member Jim P's Avatar
    Nov 2019
    No it is not the same for a 2010
    Oct 2012
    Quote Originally Posted by Jim P View Post
    Is the posted stock file for the 2012 "correct" for a 2010, no. Can it be used, yes. I am not saying that it is correct. I have had multiple CM2200 trucks show up running quite happily on a different model year file (2012 on a 2011 for example).
    Nov 2019
    The post file on this thread is for a 2012 68RFE. Can it be flashed and used on a 2010 or a 2011, absolutely. Will everything function without issue as is, absolutely not. Some functions, ie. cruise control will not work.
  1. CM2450B 68RFE Base File
    By Red Wasp in forum Cummins 6.7L
    Last Post: February 20th, 2023, 12:00 PM
  2. CM2350F 68RFE Base File
    By Twistedshafts in forum Cummins 6.7L
    Last Post: June 7th, 2021, 12:51 PM
  3. Replies: 9
    Last Post: March 1st, 2020, 10:44 AM
  4. where to get 2010-2012 CM2200 base files?
    By Chris_pat05 in forum Cummins 6.7L
    Last Post: October 4th, 2017, 06:08 AM
  5. 2012 C6 M6 Base Model - Need base file!
    By GR8GAME in forum Gen IV V8 Specific
    Last Post: April 4th, 2016, 04:44 AM
