Page 73 of 75 FirstFirst ... 23637172737475 LastLast
Results 721 to 730 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #721
    May 2014
    Quote Originally Posted by timweber View Post
    So I am new to tuning. From this post I gather that the AutoVE tuning tutorial for LS1 Controllers is outdated? Is there a step by step tutorial for how to begin tuning. I don't really want weed through these 72 pages to try and decipher what is the latest method. Thanks!
    97 Vortec, 383, whipple, marine efi, 411 controller.
    The original post is good and has been updated for the most part. Different setups may need to be tweaked a little bit but you should be able to figure that out as you go. For example... I have LTFT disabled, so my closed loop histogram portion is based on STFT, not LTFT. I've also messed around and done it based on LTFT+STFT combined.
    This is a great method for a MAF car because you can correct MAF and get a decent VE table in 1 log, without having to run open loop etc.
    Nothing beats doing an AutoVE to really dial in the VE table with a wideband....but generally CalcVET is more than sufficient.
    My car is speed density, but most of the time I still use the logic here to correct closed loop stuff with trims and WOT stuff with wideband. Again just to make it easier and more simple driving the car around like I normally would. You can tweak and combine methods as needed to suit your needs.
  2. #722
    Mar 2018
    Does this have to be competed in V7.5? When I try to connect I get the following error:Click image for larger version.
    It says I have the latest versions installed.
  3. #723
    Aug 2016
    Have you plugged in your Flashscan to your computer, opened V8, and checked for firmware updates? Not software updates.
    Sent from my Pixel 3 using Tapatalk
  4. #724
    Mar 2018
    yes, it says it's the latest version
  5. #725
    Mar 2018
    Got it. I guess I didn't have the latest version of V8. After installing that it prompted me for another V2 update.
  6. #726
    Jun 2020
    Question about the Original Post, since it was a post about tuning and how to. My questions is does GM use a combination of MAF/VE at or below the airflow switch threshold set at 4K rpm's, or is it only VE below 4k and MAF only above 4k, or some variation of the two? I am trying to understand how Gm does there tuning. Insight in to how it all goes together would be great.
  7. #727
    Below 4K: VE during airflow/airmass transients, MAF during steady state.
  8. #728
    Senior Member djv86's Avatar
    Nov 2014
    If I do this method with a vehicle with true dual exhaust. Do I need two different wbo2s ? And change the pid or would just using bank 1 be sufficient enough ?
  9. #729
    Usually use 1 WB.
    Would use 2 WB's to compare left/right banks.
    I have been using 2 WB's, I setup my correction pid to select the leaner WB on the fly.
  10. #730
    Nov 2014
    And is there a way to perform this without a wide and for non heavy engine loads ? I
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
