Page 74 of 75 FirstFirst ... 246472737475 LastLast
Results 731 to 740 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #731
    Aug 2018
    Quote Originally Posted by djv86 View Post
    And is there a way to perform this without a wide and for non heavy engine loads ? I
    If I'm reading post #6 correctly yes.
  2. #732
    Senior Member djv86's Avatar
    Nov 2014
    Quote Originally Posted by dhoagland View Post
    Let me go look see.
  3. #733
    Nov 2014
    Does that post say that if pcm is not in power enrichment mode it uses the ltft to create the corrected data and if in PE it used the wbo2 ? Or would I have to select different
  4. #734
    Nov 2014
    Default Calc.VET: correcting MAF and calculating VE (in single log)
    After
    This is before
  5. #735
    Aug 2018
    Thats the way I read it. But it seems you have to have the specific pids filtered in the correct manner...
    I'm new with EFI so I can't be much help... I have used this type of method on a different platform and everything needs to be correct.
    I chased my tail because I didn't set my IAT to degrees kelvin for my logging. Before long I had the damn thing so rich up top it ran like crap.
  6. #736
    Nov 2014
    same here. ive double checked the pids many times. i did notice at one point of my data log it read like 30 degrees of advance. although my high octane table said should be like 24 degrees. im not trying to change timing at all just clean up the fuel trims. and i only commute 2 miles to work from home at a max speed of 45mph and the truck only gets about 13mph. hopefully with perfoming the calcvet it should get a little better mpg. it already runs very dang well for a 1/2 ton truck although maybe its the max part thats helping.
  7. #737
    Nov 2014
    Usually use 1 WB.
    Would use 2 WB's to compare left/right banks.
    I have been using 2 WB's, I setup my correction pid to select the leaner WB on the fly.
    is there a way to setup the v2 under the bbx option to create a data log of the min required pids for the calc.vet theory ? so a laptop wouldnt be required for the data log ? i tried and i dont see half the calc pids under the pid options.
  8. #738
    Anybody know if there is a way to incorporate this into V8 software?
  9. #739
    May 2014
    Not sure if I implemented them 100% exactly like they are depicted in this guide, but here's my custom user calculated PIDs, located at \EFILive\V8\Config\
    [Groups]
    USER=User-Defined PIDs
    [USER]
    LTFTBEN="BEN from LTFT",factor,4
    WO2BEN="BEN from Wideband",factor,4
    SELBEN="Selected BEN from LTFT or Wideband",factor,4
    AFR="Commanded AFR from EQIVRATIO",AFR_gas,1
    OILPRES="Oil Pressure",psi,1
    WB="Wideband AFR",AFR_gas,1
    DYNAIR="Speed Density Air Flow",g/s,1
    TRANSTPS="Filter out transient TPS data",boolean,0
    CALCVET="Calculated VE from MAF",ve,4
    FTC_21="Fuel Trim Cell 21 Filter",boolean,0
    [USER.LTFTBEN]
    0=|-- USER.LTFTBEN
    1=|return (pid("PCM.LONGFT1")+pid("PCM.SHRTFT1")+pid("PCM.LO NGFT2")+pid("PCM.SHRTFT2"))/200+1
    [USER.WO2BEN]
    0=|-- USER.WO2BEN
    1=|return pid("PCM.EQIVRATIO")/pid("EXT.WO2EQR1")+(pid("PCM.LONGFT1")+pid("PCM.LO NGFT2"))/200
    [USER.SELBEN]
    0=|-- USER.SELBEN
    1=|if (pid("PCM.EQIVRATIO")>1.01) then
    2=|return pid("USER.WO2BEN")
    3=|
    4=|elseif (pid("PCM.EQIVRATIO")<1.01) then
    5=|return pid("USER.LTFTBEN")
    6=|
    7=|end
    [USER.AFR]
    0=|-- USER.AFR
    1=|return 14.7/pid("PCM.EQIVRATIO")
    [USER.OILPRES]
    0=|-- USER.OILPRES
    1=|return pid("PCM.EOPS")*32-16
    [USER.WB]
    0=|-- USER.WB
    1=|return pid("PCM.EGRS")*3+7.35
    [USER.DYNAIR]
    0=|-- USER.DYNAIR
    1=|return pid("PCM.DYNCYLAIR_M")*pid("PCM.RPM")/15
    [USER.TRANSTPS]
    0=|-- USER.TRANSTPS
    1=|return dx("PCM.TP",frame()-1,frame())/10 < 5
    [USER.CALCVET]
    0=|-- USER.CALCVET
    1=|return pid("PCM.MAF")*(pid("PCM.DYNAIRTMP_M")+273.15)/pid("PCM.MAP")/pid("PCM.RPM")*613.479*pid("USER.SELBEN")
    [USER.FTC_21]
    0=|-- USER.FTC_21
    1=|return pid("PCM.FTC")==21 and pid("PCM.SHRTFT1")==0
  10. #740
    Hi djv86,
    I just saw your post, I am sorry I missed it, happens on occassions
    The answer is this: yes, you set up BBL to log all the non calc pids for Calc.VET, you capture the log using BBL, and later when you open the log in the V7 scantool you can add the calc pids and click Save.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
