Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 2018 68 CM2350B Stock File
  1. #21
    Jul 2022
    I figured as much. Thanks for the direction.
  2. #22
    Senior Member Jim P's Avatar
    Nov 2019
    In the tune files themselves is a table that tells you exactly what Cummins fault codes are used in the tune file, the fault index table, MIL table and a table linking P codes to the fault index table. The fault index table, MIL table and J2012 P code linking table are all the exact same size and matching so the first element in each of those 3 tables are all tied together and so on down the tables. Getting whatever from that site won’t tell exactly what’s in each tune file or where.
  3. #23
    Nov 2019
    The fault index table uses Cummins fault codes so you need to use the P code table in the tune file to know exactly which Cummins fault code is using what P code.
  4. #24
    Jul 2022
    Referencing your 52210052 file I can see what you're talking about and I agree now that the SAE table doesn't do much good. ( Again I'm learning as quickly as I can and realize that was a bit off in the weeds )
    I have other hurdles to get past prior to being able to piece it together. Thank you for the help.
  5. #25
    Nov 2019
    Nope the SAE table does nothing to help
  6. #26
    Jul 2022
    It’s clear I need a bit more information than what’s floating around. Any suggestions on where to start?
  7. #27
    Jul 2022
    Any suggestions for reading the stock file? My understanding is that I will probably be best off using CalTerm or might be able to use TunerPro with a fair amount of setup.
  1. 2018 2350 Aisin Stock file
    By DaneF in forum Cummins 6.7L
    Last Post: June 16th, 2022, 06:34 PM
  2. Stock file for 2018 G56 Ram
    Last Post: April 13th, 2022, 01:33 PM
  3. 2018 dodge cme stock file
    By G60golf in forum Cummins 6.7L
    Last Post: April 4th, 2022, 01:14 AM
  4. cm2350b, ref trans stock file
    By agentr14 in forum Cummins 6.7L
    Last Post: February 19th, 2022, 06:39 PM
  5. 2018 Camaro Stock File OS 12688025
    By kangsta in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 13th, 2020, 11:48 AM
