Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Need help with no start issue
    Jan 2012
    Default Need help with no start issue
    I have a 2011 Escalade that I just did a dod/vvt delete with a mild cam, new lifters, springs, long tubes and ory and rebuilt the transmission. I removed the battery while I worked on it. took about 3 weeks. Got everything back together and loaded my base tune and it wont start. It wont even turn over. kinda like it has a dead battery. The battery is fully charged. I go to turn the key and all the dash lights turn off. can someone look through my tune and see if I missed something?
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Jan 2012
    So I missed the pin on the gear selector when I installed the valvebody. I got it to start but it dies after a few seconds. Can anyone help me please?
    Jan 2012
    Cam is a btr 218/224 .553/.553 110lsa.
    Jan 2012
    Been working on getting it to idle. I can get it to start and idle for about a min but its hunting and its not going above 700rpm beside an occasional flare to 900-1000rpm. uploaded my current tune file
    Jan 2012
    Got it to stay running at idle with little hunting. But its running extremely lean. Pegged my aem eugo wideband at 18.5. Is there a rafig or similar precess like on the old ls1 pcms
    Jan 2012
    Found a few exhaust leaks. At the exhaust collector and there a 90* turn and another lap joint and clamp. The wideband is after the 90* bend. Does anyone know of a fix that doesn't involve a welder?
    Also. My efans are not coming on. Was watching the map and clicked on data and coolant temp was at 212*F.
    Jan 2012
    Can anyone help please? I'm running around in circles trying to get this to idle right. Wo2 was saying it is extremely lean. Added fueling to the idle area now the map has shifted showing around 80kpa at idle.bg/cylinder was around .45-.55 and now it's getting .9 and only runs for a few seconds
    Jan 2012
    My idle speed also isn't what I'm trying to command. Wanting 850rpm and its around 400-700
    Jan 2012
    I started over with a copy of the stock tune file. followed the auto vve guide and the idle guide. Still cannot get it to stay idling. Im attaching my current tune and a log of several attempts to start it. the last attempt ended with the exhaust backfiring.
    Jan 2012
    Found the spark plugs fouled. Had 6 of the old ones still so put them in. It will start, Rev to 2200 then die.
  1. Cold start issue
    By 5557nut in forum Gen IV V8 Specific
    Last Post: June 3rd, 2021, 02:42 AM
  2. E38 no start issue
    By Hooter in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2020, 11:40 AM
  3. Start/Post start issue!
    By IJ. in forum Gen IV V8 Specific
    Last Post: September 3rd, 2013, 02:55 PM
  4. LS7 Hot Start Issue
    By hapnermw in forum E37, E38 & E67 PFI ECM's
    Last Post: August 20th, 2009, 05:24 PM
  5. warm start issue
    By thomas walters in forum Gen IV V8 Specific
    Last Post: October 16th, 2007, 06:40 PM
