Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Thread: 12592618 cax for 4l80e TCC unlock tables
  1. #21
    Sep 2012
    The irony is thick....I can't open my own tune file with that older version of EFI Live. @turbo_bu did you actually open my own tune file or just didn't get an error with that cax file?
  2. #22
    Sep 2012
    It says the .ctz file is not supported by that version of EFI Live.
  3. #23
    Mar 2009
    You can't have a version of EFILive that is older than the tune you're trying to open. Need to update your software.
  4. #24
    Sep 2012
    Reread the thread. I'm using a newer version but turbo bu suggested I try an older version to see if it got past the cax table errors I'm seeing. I need help getting the trans tables in the cax file not to throw an error.
  5. #25
    Mar 2009
    If that's the case, I think you'll need to use the old software to pull the new tune off the PCM (so flash new tune with new software to PCM first). Don't just try to look at the new tune through the old software if that makes sense.
  6. #26
    Sep 2012
    Haha I literally said the same thing in PM last night. I'm not convinced that's going to solve my problem but it's worth a shot. I wish some of the OG cax experts/vrrators were still around to help.
  7. #27
    Mar 2007
    ddnspider .... I opened up an existing file that I had with the same OS as yours. I knew that this older version would not touch your newer CTZ file. Unfortunately, I think that the newer version of EFILive will NOT save to an older version. One option is to use something like PCMHammer, or LSDroid to read your file as a binary. Both the newer and older versions of EFILive will read in *.bin files.
  8. #28
    Sep 2012
    Quote Originally Posted by turbo_bu View Post
    Im going to do a read on what's in the truck with the older version of EFI Live and try to apply the same cax file and see what it does. Since you were able to open a file with my OS, can you try and apply the cax and see if it gives you an error?
  9. #29
    Mar 2009
    That would solve another issue I thought of: firmware. New and old versions of software probably won't talk to the same version of firmware. . . right?
  10. #30
    Mar 2007
    Quote Originally Posted by Supercharged111 View Post
    Yes, I think this becomes the issue. You can use the older 7.5 all you want, but it probably won't connect with your V2 that has been updated with the newer version of firmware which matches your newer version of EFILive. I am pretty sure that you can not downgrade your firmware either on the V2 to match this older version of EFILive. The proverbial catch 22.
    I was able to open my tune file which matches your OS and make some changes using your CAX file. It saved ok, and I was able to re-open it and the changes were there. I did not flash it into a PCM.
  1. 4l80e tcc throttle close cax
    By TrendSetter in forum CAX Files
    Last Post: February 8th, 2023, 03:57 AM
  2. 12592618 b9021 CAX file
    By 5.7ute in forum CAX Files
    Last Post: January 19th, 2023, 02:57 PM
  3. Stop TCC unlock when coasting?
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 27th, 2010, 02:47 PM
  4. any 01/02 4l80e trucks NOT unlock tcc on decel
    By Cablebandit in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 4th, 2007, 02:35 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
