Results 1 to 2 of 2
Thread: Do you adjust 'Desired Boost Med Altitude'?
    Feb 2023
    Default Do you adjust 'Desired Boost Med Altitude'?
    Hi all
    As per my earlier post, I've got an Australian 2014 RG Colorado manual with the 2.8Lt Duramax, tuned for towing with max boost/MAP of 300kPa (up from 258kPa max here looking at a stock file)
    I'm having a strange lack of power when going to higher altitudes over 500m (1500ft) which first occurred over 2.5 months ago. At first I thought I have a boost leak and have had 2 mechanics look at the car extensively, but car is fine back at sea level and has never logged any trouble codes.
    Speaking with the tuner who did the remap, they are adamant it is not related to the tune, but did mention something interesting, that they don't touch the med/high altitude boost maps to prevent turbo overspeed etc.
    I'm looking for a 2nd opinion - when others are tuning a Colorado / Duraxmax or other diesel with an E98 ECU, do you change the 'Desired Boost, Med Altitude' map as well as the low altitude base map?
Name:	EFI Live Med Alt Desired Boost 2400rpm.png
Name:	EFI Live Low Alt Desired Boost 1800rpm.png
    Comparing the Desired Boost Low/Medium altitude on the stock file appears to target similar boost levels, just the Medium altitude is higher in the rev range around 2400rpm.
    Thanks in advance
    James
    May 2024
    Quote Originally Posted by jb007 View Post
    Hi all
    Thanks in advance
    James
    I'm new and I had the same problem.
  1. What is Low/Med/High Baro? & a VVT ?
    By MN C5 in forum Gen IV V8 Specific
    Last Post: April 12th, 2016, 08:48 AM
  2. Timing, Boost Adjust D6270 & D6273
    By kaiserbailey in forum Cummins 5.9L
    Last Post: July 11th, 2012, 03:42 PM
  3. Timing, Boost Adjust D6270
    By FUBAR in forum Cummins 5.9L
    Last Post: January 22nd, 2012, 08:40 AM
  4. LMM and LBZ DSP5 Desired boost tables not looking up correctly
    By vortecfcar in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 26th, 2010, 04:00 AM
  5. How does desired boost work?
    By pistonrings in forum Duramax LLY
    Last Post: May 30th, 2009, 04:47 AM
Tags for this Thread
