V8.3.38 Public Release (Update 1 for V8.2.37)
Full Release Notes:
Version Numbers:
After installing this release you should have the following software and firmware versions installed:
- EFILive V8 software: V8.3.38
- FlashScan/AutoCal V3 Firmware: V3.00.106
Download here:
Known Limitations: Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
Limitation #2: When opening CMF (CM2450B) Cummins 2022 tune files, the EFILive software will complain with the following message:
That is expected and the message may be ignored. We have only added the option to open CMF 2022 stock files so that EFILive can flash stock files. EFILive cannot be used to update the check sums of modified files. Modified files cannot be flashed.
Ignore the message if you are opening and flashing a 100% stock tune file. Do not attempt to flash a modified file, it will fail at the end of the flash and the vehicle will be left in a no-start condition until a stock file is flashed in.
Workaround: None.
Limitation #3: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
Known Issues:
Issue #1: When flashing CME/CMF (CM2350B/CM2450B) Cummins controllers with AutoCal/FlashScan V3 devices the flash can sometimes fail with error $0322.
Workaround: Download and install firmware update V3.00.107 attached to this thread.
Issue #2: *.cax8 files containing blank lines that contain one or more space characters will fail to load with the error "Index out of range".
Workaround: Remove the spaces from blank lines, or remove the blank lines.
Regards,
The EFILive Team
