Any new info when the OS will be released? I have several customers waiting on this. Im also waiting but Im about to just order the nitrous and give on this along with V2.
I can post it up I guess but you will be on your own without a tutorial!.
Though, the N20 stuff is pretty simple, it's the TPS VE that might cause some grief, but if you don't use that then there is no issue.
ooo yes please, post please
2014 VF SV LS3 Maloo.
I'll try and get the tutorial done in the next week or so for you guys.
Hey we dont need tutorials man. Half the fun is in figuring it out yourself.
On this one you will be like for the first few mins without any direction. At least I was. Its not difficult by ANY meands, just a few steps to go through before you can actually start using the tables.Originally Posted by ringram
That's fair enough. Atleast then I can look through the OS and see what all nitrous parts I still may want or need to buy.Originally Posted by GMPX
I thought directions where like the answers in the back of the book, they are for checking your work after your done.
Hey Ross,
In the V5 Custom OS does the TPS VE Table get multiplied by the VE Multiplier table (B0014) as well as the standard VE Table?
Andrew
EFILive Crew
