Results 1 to 5 of 5
Thread: 411 wiring diagram
    Jul 2023
    Default 411 wiring diagram
    How do you get a hold of Lextech. I
    PM me.
    I have the spreadsheet your looking for if your doing s vortec to LS1B pcm
    Jul 2023
    So I don’t know what that is as I am not familiar with any thing newer than the black box for the vortec and I know they call the 1 I’m going to is referred to as the “411” ECM and was used on both the vortec and LS engines. I have a diagram but it doesn’t show all the pins that are used for my 98 k3500. So if that’s what you have I absolutely could use it. I would think that the newer ECM would have more separate return wires for the sensors instead of having them all solder together
    Jul 2023
    My email is [email protected]. Thank you
    Apr 2024
    Hello, who can help me with a cable diagram to change the pins for a PCM Black Box Blazer 99 4.3 v6 to 0411. I am from Venezuela and I would like your help. I also want to put a set of ls1 coils on it and I think I should use 60-2 crank trigger wheel?
  1. Wiring diagram of truck transmission shift range thingy
    By turbo_bu in forum Gen III V8 Specific
    Last Post: May 24th, 2013, 04:12 AM
  2. LBZ bench harness wiring diagram
    By boothybunch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 18th, 2013, 04:46 AM
  3. Replies: 1
    Last Post: January 31st, 2013, 08:22 AM
  4. looking for pcm pin outs and wiring diagram
    Last Post: February 6th, 2010, 07:03 PM
  5. VX-VY 5.7 wiring diagram
    By shane in forum Gen III V8 Specific
    Last Post: September 24th, 2009, 02:59 PM
