Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: Need help with no start issue
  1. #41
    Jan 2012
    Also, once the p0101 sets it goes back to the vve and drives like normal
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
  2. #42
    Jan 2012
    Seems like the maf was waaay off. Going very lean at light throttle and the difference between the maf and vve caused the p0101 and the maf to fail. Ended up having to add 20-50% more to the maf table but it's running much better now
  3. #43
    Jan 2012
    What would cause the transmission to shift early on the 1-2 wot shift? I have it set to 6000rpm and 40mph. But its shifting at 5700rpm and 37mph. Have the 2-3 shift set at 6100 and 68i belive but its shifting at 6300-6400rpm. It's commanding the shift where i want but it doesnt shift right away. Also no matter how I start a wot run, off idle or reving to 200-2500 the rpms go to 3000 slowly climb to 3300ish then takes off. I can post my tune and some logs in the morning.
  1. Cold start issue
    By 5557nut in forum Gen IV V8 Specific
    Last Post: June 3rd, 2021, 02:42 AM
  2. E38 no start issue
    By Hooter in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2020, 11:40 AM
  3. Start/Post start issue!
    By IJ. in forum Gen IV V8 Specific
    Last Post: September 3rd, 2013, 02:55 PM
  4. LS7 Hot Start Issue
    By hapnermw in forum E37, E38 & E67 PFI ECM's
    Last Post: August 20th, 2009, 05:24 PM
  5. warm start issue
    By thomas walters in forum Gen IV V8 Specific
    Last Post: October 16th, 2007, 06:40 PM
