Results 1 to 4 of 4
Thread: Updated PMMs for E38 E67 E92 LS1B
    Jul 2003
    Default Updated PMMs for E38 E67 E92 LS1B
    Hello Everyone
    I've been meaning to release this for a while. I hope everyone finds this useful and this might be a good addition to everyone's scanner. This has most parameters I typically use that are not defined within EFILive. You can find these parameters by going into the ECM Custom area Make sure to validate the PIDs. If there is one that is really important let me know and I may attempt to add it.
    Drop these into: C:\Users\<YOUR USERNAME>\Documents\EFILive\V8\User Defined PIDs\pmm
    Thanks!
    Al
    Sep 2003
    Ok, I put the E92_User.pmm file in the pmm folder that's in the User Defined PIDS folder. I validated PIDS with V8 while connected to my car but nothing new shows up under "ECM Custom". What am I doing wrong or does it not work for E92 Controllers ?
    Thanks,
    Walter
    May 2010
    Thanks a lot but it will be better to illustrate for what is this
    EFILive Tuner
  1. V8 LS1B vs E38
    By nonnieselman in forum V8 Tune Editor
    Last Post: May 24th, 2022, 01:28 PM
  2. Replies: 2
    Last Post: March 6th, 2019, 08:46 PM
  3. HELP, can't flash LS1B after E38 licence
    By O1Z06 in forum FlashScan V2
    Last Post: January 8th, 2013, 04:21 PM
  4. E67 supported vehicles & Cal files (Updated 21-October-2008)
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 18th, 2010, 12:42 AM
  5. E38 supported vehicles & Cal files (Updated 21-October-2008)
    Last Post: June 17th, 2007, 01:04 PM
