Results 1 to 8 of 8
Thread: What parameters activates PE?
    May 2023
    Default What parameters activates PE?
    Hi
    When I scan my car (LQ9 with LS1B PCM) the commanded AFR is 14.63 all the time (except for two short spots). What parameters activates PE?
    My car running lean at load. Should B4206 be enable or disable?
    Am I missing something?
    KR/ Magnus
    Mar 2009
    Replying from my phone, make sure the PE Delay timer is set to 0. I forget what the LQ9 had stock, but the LQ4 had a 60 second timer.
    May 2023
    It is set to 0 sec but it does not activate.
Name:	LQ9 Screen shot.JPG
    Nov 2014
    check if your b3616 is not set too conservatively. or just step on it.
    Post pics of the other PE enable tables,
    Your datalog shows to be doing what the tune is telling it to do. It goes into PE at frames 2197 and 5352 because the settings in B3616 were met.
    If you want to bring PE in sooner just lower B3616
    Nov 2014
    im afraid we are a little late to the party.
    Ah.. 6 month old post....
  1. COS3, STFT activates under boost!?
    By jeffro in forum Gen III V8 Specific
    Last Post: July 9th, 2018, 08:14 AM
  2. I need some help with system parameters
    By chevypower in forum Petrol / Gas
    Last Post: June 27th, 2015, 12:07 PM
  3. New A6 Parameters
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 15th, 2009, 08:33 PM
  4. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  5. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
