Results 1 to 2 of 2
Thread: E38 Fuel pump relay control while cranking
    Oct 2019
    Default E38 Fuel pump relay control while cranking
    Hi all,
    I am wondering how to replicate the fuel pump relay staying on while the engine is cranking?
    I have a stand alone setup with an E38 running an L77. I know the fuel pump will run for 2 -3 seconds when the ignition is initially turned on.
    If commanding the starter replay externally from the ECU, will the fuel pump run from the low rpm signal it sees from the crank angle sensor? Or should I use a diode protected feed from the start relay to the fuel pump relay to make the pump run while cranking?
    Thanks in advance for your thoughts,
    Des
    Hi Des,
    The ECM will run the fuel pump as long as it sees the crank position sensor
    i.e. fuel pump will run during cranking (ECM has cranking fuel tables).
    If ECM is not pulling the fuel pump relay, then there is a fault which neefs to be diagnosed.
  1. Replies: 12
    Last Post: March 9th, 2018, 06:46 AM
  2. Fuel Pump won't work.. but car runs fine with relay bridged?
    By auspeed in forum Conversions / Aftermarket Parts
    Last Post: February 16th, 2015, 12:03 PM
  3. Bad ECU? Trailblazer SS, only 5.7 volts at fuel pump relay
    By Praxis in forum Gen IV V8 Specific
    Last Post: October 1st, 2014, 12:32 PM
  4. Using the AC relay output to control a second fuel pump
    By ttls1 in forum Gen IV V8 Specific
    Last Post: December 31st, 2013, 11:13 PM
  5. fuel pump relay constantly switching
    By steve40 in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:32 PM
Tags for this Thread
