Results 1 to 8 of 8
Thread: 2016 Chevrolet 3500 LML
    Feb 2024
    Default 2016 Chevrolet 3500 LML
    Hey guy's, Well I'm new to the forums, based in South Carolina I own a Diesel repair and performce shop. I have used many EFILive devices in the past and current. I am currently having a issue with a vehicle im my shop. I was hoping I could get some insite on this current issue.
    I have a 2016 Chevrolet 3500 high country with 339k miles on it the owner has taken very well of this truck I have been working on it and servicing it for 3 years for him. A few months ago he dropped it off said it was running bad and skipping. I discovered it had a hole in the number 1 piston looked to be melted also. So we installed a Long block, whole new fuel system, BD Power diesel 64mm screamer, Banks welded charge air cooler with bigger pipes. (It was already tuned before it came to me.) Programmed the IQA codes, confirmed the IQA codes with GDS2 programmed them to GPCM and reset fuel learned values, went for a test drive and im feeling a shutter at 45-70 mph only when you load the engine in 5th gear. I get random injector balance and timing codes some times it may be 1,4,5 other times it will be 6,3,8,5 then again it will be 2,8,6,3 or 1,4 or 6,8 its random they are exceed learing limint injection timing and injection balance.
    P02D9, P02D3, P02D7, P01D8, P01D2, P0263, P01D6, P0281, P0272, P0278
    when TCC is in this happens see attached..
    https://imgur.com/rzgZNTs
    https://imgur.com/U5u6SA1
    https://imgur.com/8Bcn3VK
    The long block and fuel system came from jasper engines, I called tech support they are telling me that the TCC can cause the crank to feel that torque converter locking up and shuddering which in return could cause the injector codes. When I went back and test drove the truck I commanded the TCC off while the truck was shuddering and the shuddering went away. If i drive under 45-60 with no load I dont get the injector codes.
    What I have done?
    Retuned engine
    Overlayed all injector circuits to each injector, changed IQA codes for giggles, changed MAP changed MAF, Truck has a air dog fuel pump has good flow and 10-12 psi supplied to the pump on the engine, timing it set CP4 pump gear dont between cam gear dots.
    Can a locking or slipping converter cause random injector balance codes under a load in 5th gear between 45-70?? it's a new one to me
    Any help would be grateful!!!
    Senior Member djv86's Avatar
    Nov 2014
    see if you can watch tcc slip speed command vs tcc slip speed actual. when it slips over 130-150 when being commanded 0 tcc slip thats probably when you start feeling the shudder. if you can command full tcc lockup while its shuddering and it goes away the tcc is just worn and glazed over. the trans fluid will also have a distinct scent.
    also you need to make sure to perform the crank variation learn after engine replacement as well.
    Feb 2024
    I know for sure it’s coming from the converter but could that really be causing the injector codes? That’s the big question I have about it.
    Nov 2014
    hard to say really. although if the vehicle is trying to stay at a steady rpm and if fluctuates it may be hard for the ecm to inerpret the fact that its not fuel related. it may just assumed that its something else. but have you performed the crankshaft variation learn ?
    Nov 2014
    Circuit/System Verification
    1-Verify the proper fuel is used. Refer to Fuel System Specifications and Contaminants-in-Fuel Diagnosis.
    2-Verify there are no aftermarket performance enhancing devices installed on the vehicle.
    3-Perform the Fuel Injector Correction Reset for the appropriate fuel injector. Refer to Fuel Injector Correction Reset.
    4-Perform the Crankshaft Position Reluctor Wheel Learn. Refer to Crankshaft Position Reluctor Wheel Learn.
    5-Perform the Fuel Injector Timing Learn to verify that the DTC does not reset. Refer to Fuel Injector Timing Learn.
    If DTC resets
    Refer to Circuit/System Testing.
    If DTC does not reset
    All OK.
    1-Perform a engine compression test. Refer to Engine Compression Test.
    2-If engine compression is not within specification
    Repair as necessary.
    If engine compression is within specification
    Replace the appropriate Q17 fuel injector.
    Feb 2024
    Update changed torque converter shudder went away, codes still the same!!! Jasper sent 8 new injectors and still same issue, swapped ECM, changed Tune same issue, replaced wire harness same issue, Jasper sent a new engine I swapped the engine and same issue injector 1, 8 exceeded learning limits. Cam and crank sensor has been changed, S&S diesel CP3 swapped. Same result no change…… I’m at a lost !! Any ideas?
    Nov 2012
    Default Have the EXACT same issue and I'm lost!!!
    I am having the EXACT same issues that you're describing and have tried many of the same things to resolve it without success. I have checked everything I can possibly think of and am at a loss. Truck has the 2nd new motor, new injectors, balance rates are good, compression test was perfect, etc. Did you ever figure out what was causing the issue and get things resolved? If so, could you PLEASE share that info because I'm completely stumped on this one and don't even know where to look next . Thanks in advance for any info you can share.
    Feb 2024
    The fix was return the ECM to stock, yea you will have light on the dash and messages but you will have X till reduced engine power
    Return to stock
    Clear codes
    Go back and now program the IQA codes to the ECM copy to the GPCM
    Confirm your IQA codes
    Reset fuel min max values
    Now go drive the truck perform the crank relearn
    Once complete you can put the tune back in the ECM
    If you have any issues don’t hesitate to direct message me and we can chat on the phone
  1. 2016 candc LML
    By Ltcbm in forum Duramax 2011+ LML / LGH
    Last Post: November 13th, 2022, 05:27 AM
  2. Need bailed out on an 2016 LML
    By randomdude in forum Duramax 2011+ LML / LGH
    Last Post: August 29th, 2022, 09:21 AM
  3. 2012 chevrolet silverado LML
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: February 4th, 2018, 07:02 AM
  4. 2016 LML haze at idle...
    By 02CCSB in forum Duramax 2011+ LML / LGH
    Last Post: January 9th, 2018, 03:59 AM
Tags for this Thread
