Results 1 to 5 of 5
Thread: Revision, 6l80e will not rev past 5k in gear, no up-shift at wot.
    Junior Member undergroundak's Avatar
    Apr 2011
    Default Revision, 6l80e will not rev past 5k in gear, no up-shift at wot.
    Yo EFI live,
    I'm re-posting this, assuming I may have given too much info before.
    We have a 2011 5.3 boosted with a spot on (part throttle) 6l80 tune.
    I can rev the truck in park and neutral beyond 5k (6k limiter) but it will not rev beyond 5k in gear and it is refusing to upshift unless its at 80% or less throttle.
    I can lower all my shift speeds (tested it) and it will shift fine @ 5k. What would stop the engine from revving past 5k in gear?I'm stumped.
    THanks,
    Nick
    2011_5.3_6speed_tcm_trqraised_0001.tun
    Underground Performance
    (907)349-1555
    undergroundperformance.us
    EFI Live
    Diablo Sport CMR
    GM Chrysler and Ford
    It might be something in the ECM tune.
    Aug 2006
    Hi , I know this is a super old post but I'm.currently having the same problem with a l98/6l80e conversion into to a land rover , stand on throttle it will kick back gears in till it gets to 5000rpm and just sit there?, did you sort the problem underground?
    Aug 2006
    Quote Originally Posted by JCA View Post
    Make a new thread and post your tunes and datalog of the issue.
  1. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
  2. Need help on 99 454, cant rev past 4800
    By mathis in forum Vortec V6/V8 Specific
    Last Post: April 9th, 2011, 07:49 AM
  3. rev limiter per gear not limiting
    By ryans1000 in forum General
    Last Post: August 25th, 2010, 04:30 PM
  4. 6l80e shift time completion
    By b18cls1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 14th, 2010, 02:58 PM
  5. Hitting the rev limiter on the 2-3 shift at WOT...
    By waveoff in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 14th, 2007, 11:23 AM
