Good day. its been about 15 years since i have actually used a forum but i must admit i am at my wits end trying to tune my lly. so heres the skinny
tunes are from calibrated power. i removed the following fuses. Radio, radio amp, info and abs. i went as far as to removed the main fuse for my subs, lift pump fuse has also been removed. i currently have a tap shifter conversion for the trans that uses a fuse tap in the cab fuse box. i removed the conversion harness at the tcm and arranged it back to factory, the fuse tap has also been removed for the tap shifter. i also went ahead and removed the radio completely as well as the radio interface module.. now here is my issue
i could not get the tunes to load the traditional way with the autocal v3. i contacted calibrated power and was instructed to do a pass thru. Our laptop is a bit on the older side and uses windows 10. i fought the full flash for just about a day when i finally got it to take.. kind of. i got as far as licensing the autocal and during the "program" process i got booted with the dreaded 0101 no data received code. now my truck will not start and current dtc is u1000. i was only able to get this far by using the " stock key", "assume lock me faulty", and " try additional strategies" selected, high speed was not checked during this process. Ive repeated the previous steps multiple time and everytime i get to the "erase file" and then it boots me at the "program" portion. ANY help would be appreciated. i also downloaded efi 7.5 i can pull of the tunes (both stock and calibrated power) tune files but i cannot get the program to connect to my ecm.
edit firmware and bootblock are up to date on v8
