Results 1 to 4 of 4
Thread: 2015 Silverado L83/6l80 2wd file needed
    Aug 2010
    Default 2015 Silverado L83/6l80 2wd file needed
    I am trying to locate a 2015 l83/6l80 2wd file for OS 12664769, I am working on a swap vehicle with a full 4wd pullout where the 6l80 was converted from 4wd to 2wd and now that the transfer case has been deleted, We are getting a P279B DTC. The table to change from 4wd to 2wd and/or VSS type is not defined in this OS, So I am thinking the only way around it would be to switch to a 2wd base file.
    Thanks!
    Quote Originally Posted by Hammered94 View Post
    Thanks!
    Ive got several 2015 tunes ive read off over the years. Is there a way to see if its 2wd or 4wd in the tune?
    Aug 2010
    I haven't been able to determine what indicates 2wd from 4wd in any of the files that I have found floating around, I did find a 2015 Tahoe L83/6l80 file that the owner indicated was 2wd. Same OS number 12664769. I am going to copy over all of my calibration settings and give this one a try sometime this week when I have time.
    I believe the 5th digit of the VIN tells you - K for 4x4 or C for 2x4. If I'm not mistaken.
  1. 2019 L83 and 6L80 Standalone
    By BrokenAxle in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 10th, 2022, 03:27 AM
  2. Replies: 0
    Last Post: March 23rd, 2022, 05:46 AM
  3. 2015 L83 Stand Alone
    By oreobadr in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 28th, 2019, 11:13 AM
  4. Needed - 2013-2014 Silverado/Express 6.0L stock file
    By gixxer92 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2017, 07:24 AM
  5. 2001 Silverado 2wd PCM into 2000 Silverado 4wd
    By LastCall in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 12:52 PM
