Results 1 to 3 of 3
Thread: Pilot and Main Timing for economy
    Sep 2018
    Default Pilot and Main Timing for economy
    Getting ready for traveling season. I've been working on a "daily driver tune" to net better economy. I will post what I have for mapping when I gain access to my laptop again. I currently have pilot tapering off to zero at 2500rpm.
    Just looking for generalized tips of what to do. I am running 15mpg currently on a tune that is roughly 500rwhp and has moderate smoke limiting below 2200rpm.
    I was running a billet S363/68 that I sent to the moon last spring. I was running 16mpg with it regularly. After the S472, I made extensive changes to the tune to get back to the 15mpg mark, but would like try and get closer to 17-18 highway.
    Hardware:
    2010 F250 Super Crew long bed
    Short Rod 6.4L CR
    Fly cut 6.7 pistons
    Hamilton 188/210 cam
    CM849/custom harness
    Exergy %100 CRIN1 injectors
    Fleece Powerflo 750 injection pump
    Forced S472 (I don't remember which turbine ATM)
    47RE with all the goodies
    Anteater Beta controller
    3.73 ratio axles
    33" tires
    Sent from my motorola one 5G using Tapatalk
    Sep 2018
    Well, my laptop is having an issue. I'll post up as soon as I get it rolling again.
    Sep 2018
    Main timing was derived from AH64's spreadsheet calculator.
    I need to rework the pilot timing scale and values because it's too close to my part throttle shift point and causes what amounts to a PID hunt right before the shift as pilot shuts off and then comes right back because of the change in torque.
  1. pilot injection and pilot timing tables?
    By Scarface in forum Cummins 5.9L
    Last Post: January 9th, 2017, 06:29 AM
  2. Replies: 13
    Last Post: March 25th, 2016, 05:02 AM
  3. Main Injection vs. Main Injection (No Pilot)
    By WisconsinHick1 in forum General (Diesel)
    Last Post: April 7th, 2013, 06:04 AM
  4. Pilot vs No Pilot Main Pulse Map
    By brossjd in forum Duramax LLY
    Last Post: August 7th, 2012, 10:41 AM
