Results 1 to 3 of 3
Thread: Throttle position sensor fluctuating at WOT
    Mar 2024
    Default Throttle position sensor fluctuating at WOT
    Hey guys, I'm new here and just have a question. I have a 13 Buick Verano turbo that was tuned by BNR and I have lately had an issue with it stumbling/ hesitating at or near WOT. I logged some data on this yesterday and noticed my TPS percentage fluctuating from steady at 84.7% down to 72% when I know I was at WOT. Is this normal, or is my tps going bad. I know the 84 is normal, but shouldn't it be staying there until I lift? I've noticed extremely high idle occasionally as well during cold start. Like 2000 to 2500.
    Oct 2020
    Immediate thought is how old are the plugs and the coils? High rpm misfire is can be related to either one of those. Old plugs can increase the gap and get spark blowout or just misfire or bad coils can misfire. Look at your log and misfire for each cylinder to see if what cylinder the misfire is happening. Since the Verano uses individual ignition coils you can just do a coil swap from one cylinder to another to determine if it's the coil.
    Jul 2024
    Clean the throttle body and the IAC valve. Carbon buildup can affect throttle response and idle speed. mapquest
  1. No crank position sensor signal
    By Fuzzman in forum General (Petrol, Gas, Ethanol)
    Last Post: December 8th, 2019, 04:44 AM
  2. Throttle Position (TP%)?
    By beav in forum Diesel
    Last Post: July 1st, 2013, 11:32 PM
  3. Which PID with E38 ecm to show 100% throttle position at WOT
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 12:52 PM
  4. Throttle Position
    By bstuder11 in forum Gen IV V8 Specific
    Last Post: April 7th, 2012, 11:12 PM
  5. Crankshaft Position Sensor Code
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 03:08 PM
