Results 1 to 10 of 20
Thread: 2016 ram 2500 6.7 tune failed
    May 2024
    Post 2016 ram 2500 6.7 tune failed
    Trucks getting fixed how do I delete this thread? Lmao.
    Senior Member Jim P's Avatar
    Nov 2019
    Do you have an AutoCal or FlashScan? Basically the tuner didn’t set up your device correctly and it doesn’t have the required files loaded on it.
    Nov 2019
    If I was back home, just south of Calgary I would come help you out but I’m in Louisiana till end of next month
    Mar 2022
    That error code means the BBX settings are incorrect. Install Efilive V8 on your computer, if you haven't already. Connect your Autocal to the computer. Open the F5: BBX tab in Efilive Scan and Tune. select Read at the bottom of the screen. Then look under the Tune tab and see if any controllers are listed. The one you need is CME CM3250B. Add that one if it isn't loaded already. Then select Program at the bottom of the screen. You should now be able to flash your truck.
    I don't tune many Cummins trucks, and I've never bricked one, but on Duramax's, Efilive has a recovery mode if the previous flash failed. It just may get your truck working again.
    Nov 2009
    Send me a pm, I can't send u one for some reason. Sounds like your autocal needs Bbx redone on it.
    May 2024
    For some reason I can’t send you a message aswell.
    May 2024
    The files are not bbx unfortunately
    May 2024
    Yes efi live auto cal v3
    Nov 2019
    The bbx needs to be set up on the autocal, the tuner should have done that before sending or before trying to write the tune to the truck
    May 2024
    They used a AMDP tuning file I asked after talking to another tuner and he said they should be bbx I talked to the person that tried to tune the truck and he said they are not bbx files is there a way I can convert them to bbx files?
  1. 2017 ram 2500 6.7 68ref stock tune file
    By davidwhitaker in forum Cummins 6.7L
    Last Post: May 7th, 2024, 03:49 AM
  2. Dyno Tuning RAM 2500 68RFE
    By Truck-Tuning in forum Cummins 6.7L
    Last Post: March 28th, 2023, 09:59 PM
  3. Need 2016 Ram 2500 with AISIN transmission.
    By TurboTim in forum Diesel
    Last Post: August 21st, 2022, 06:47 AM
  4. 2020 brazilian ram 2500
    By romulo_sampaio in forum Cummins 6.7L
    Last Post: January 9th, 2020, 09:59 AM
  5. looking for base tune 2013 ram 2500 6.7 manual.
    By TZapoluch in forum Cummins 6.7L
    Last Post: September 16th, 2019, 11:46 AM
