Results 1 to 5 of 5
Thread: vertical and horizontal scale swap?
    Jun 2020
    Default vertical and horizontal scale swap?
    New to EFIlive. Is it possible to swap the horizontal scale with the vertical scale in v7.5 Tune?
    Not in V7.5, I believe that's a planned feature in the V8 editor (but cant remember where I saw that, so don't quote me on it).
    If it really bugs you, copy/paste into Excel and transpose the axes.
    The V8 editor can do this, the Cummins ECM's are being converted to work in V8 now.
    Dec 2005
    USE V7.5 "COPY WITH LABELS"
    Then "PASTE WITH LABELS"
    TheN "Transpose"
Name:	V7.5 TRANSPOSE AXIS FUNCTION.png
    www.mscservices.net
    Nov 2014
    this doesnt seem to be working. it doesnt paste with labels (mismatch) and no transpose option comes up. ?
    edit: found this
    "Click on the "Conversion" menu. Import a table & push the "Transpose"button."
    "In V7.5 there is a "Conversions" tab at the top right ... you can create a table then switch the axis by using the "Transpose" feature"
    dont see a conversion menue or tab in 7.5.
    (working with an ls1, maybe its different? quotes from general section, though)
  1. E92 Driver Demand Vertical Axis Clarification
    By Redline Motorsports in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 12th, 2019, 03:22 PM
  2. VE table scale up by how much?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:23 PM
  3. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
  4. Blue Grey scale block.
    Last Post: November 28th, 2005, 04:04 PM
