Results 1 to 3 of 3
Thread: June 06, 2024, V8.4.55 Public Release - Update 1
    Default June 06, 2024, V8.4.55 Public Release - Update 1
    V8.4.54 Public Release - Update 1
    Pay particular attention to the warnings below - once you have updated your FlashScan/AutoCal firmware to this latest version you cannot "go back" to using the previous firmware or software versions.
    WARNING for FlashScan/AutoCal V2 users:
    Firmware versions V2.08.199 and later are ONLY compatible with the EFILive V8 software, they are NOT compatible with any version of the EFILive V7.5 software.
    You
    SHOULD only update the firmware to version V2.08.199 or later if you intend to use the EFILive V8 software.
    You
    SHOULD NOT update the firmware to version V2.08.199 or later if you intend to use the EFILive V7.5 software.
    NOTE: The V7.5 software is no longer actively supported - EFILive does not provide technical support for the EFILive V7.5 software.
    WARNING for FlashScan/AutoCal V3 users:
    Firmware versions V3.00.122 and later may only be rolled back to firmware version V3.00.114.
    WARNING for all users:
    Tune files saved using the latest EFILive software cannot be used with previous versions of the EFILive software.
    Tune files saved using previous versions of the EFILive software can be used with the latest EFILive software.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.4.55
    • FlashScan/AutoCal V3 Firmware: V3.00.123
    • FlashScan/AutoCal V2 Firmware: V2.08.207
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    Issue #1: When using filename templates for scan or tune files, filenames with multiple dots are truncated improperly.
    Workaround: Install V8.4.55 (Update 1) - don't forget to update your FlashScan/AutoCal firmware.
    Issue #2: CMB (CM849) controllers are failing to flash and/or recover from a failed flash.
    Issue #3: E35 (LBZ/LMM) controllers are failing to flash and/or recover from a failed flash.
    Regards,
    The EFILive Team
    Member koolky's Avatar
    Aug 2013
    I'm getting error $0503 when trying to Cal flash an E40 ECM from V8. "Executing: C:\Program Files (x86)\EFILive\V8\Config\E40_W.obj" E40_W.obj is at the file location. The Flashscan V2 firmware and files are up to date.
    Hi Koolky,
    Can you log a support ticket here: https://service.efilive.com/new-ticket
    Please include the appropriate trace file.
  1. May 05, 2024, V8.4.53 Release Candidate 2
    Last Post: May 19th, 2024, 03:10 PM
  2. Apr 27, 2024, V8.4.52 Release Candidate 1
    Last Post: May 4th, 2024, 06:28 PM
  3. Apr 13, 2024, V8.4.51 Beta Release
    Last Post: April 26th, 2024, 05:42 PM
  4. Apr 11, 2024, V8.4.50 Beta Release
    Last Post: April 12th, 2024, 11:03 AM
  5. Mar 23, 2024, V8.4.48 Beta Release
    Last Post: April 7th, 2024, 12:47 AM
