Thread: June 18, 2024, V8.4.56 Public Release - Update 2
    Default June 18, 2024, V8.4.56 Public Release - Update 2
    Pay particular attention to the warnings below - once you have updated your FlashScan/AutoCal firmware to this latest version you cannot "go back" to using the previous firmware or software versions.
    WARNING for FlashScan/AutoCal V2 users:
    Firmware versions V2.08.199 and later are ONLY compatible with the EFILive V8 software, they are NOT compatible with any version of the EFILive V7.5 software.
    You
    SHOULD only update the firmware to version V2.08.199 or later if you intend to use the EFILive V8 software.
    You
    SHOULD NOT update the firmware to version V2.08.199 or later if you intend to use the EFILive V7.5 software.
    NOTE: The V7.5 software is no longer actively supported - EFILive does not provide technical support for the EFILive V7.5 software.
    WARNING for FlashScan/AutoCal V3 users:
    Firmware versions V3.00.122 and later may only be rolled back to firmware version V3.00.114.
    WARNING for all users:
    Tune files saved using the latest EFILive software cannot be used with previous versions of the EFILive software.
    Tune files saved using previous versions of the EFILive software can be used with the latest EFILive software.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.4.56
    • FlashScan/AutoCal V3 Firmware: V3.00.124
    • FlashScan/AutoCal V2 Firmware: V2.08.207
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    Jul 2003
    Getting a script file invalid $0503 randomly when attempting to flash. I thought it was a fluke with an LS1 ECM but today its an E40. Using an older V2. Any ideas?
    Mar 2007
    If I would like to still use the V7.5 software, which version of EFILive and firmware should I download?
    The *.obj scripts from the latest V8 software are not compatible with older V2 and V3 firmware.
    You cannot mix/match old firmware and new software - or old software and new firmware.
    Make sure both your software and firmware is updated to the latest release.
    Regads
    Quote Originally Posted by turbo_bu View Post
    The versions/compatibility are explained in the first post.
  1. June 06, 2024, V8.4.55 Public Release - Update 1
    Last Post: 4 Weeks Ago, 09:51 AM
  2. June 2021, V8.3.7 Public Release
    Last Post: August 6th, 2021, 02:58 AM
  3. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  4. Public Release Update June 24, 2011
    Last Post: July 9th, 2011, 06:21 AM
  5. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
