Hello,
I have a LS1 Auto. The main problem i have i coasting at 40 to 70 km the idle hangs on at around 1100 rpm and the car doesn't slow down. I think it is in the throttle follower but not sure what part requires attention
Any suggestions?
Hello,
Any suggestions?
- Diane - geometry dash lite
To fix this you will have to do a bit of fudging on a few tables. You need to make sure idle timing gets enabled and create a pocket on idle area so ecm interpolates between 800-1200 cell and stays close to your desired idle coasting speed.
