Thread: V6 411 ECU base tune
    Mar 2007
    Default V6 411 ECU base tune
    So here is what im playing with. Honda V6 with a retro fitted 24 tooth reluctor for the 411 ECU, the plan is to use a std LS1 throttle body and wire it for the 411 ecu. Can someone help me with a std 411 V6 tune that I can use as a starting point
    Thanks Mike
    Do you know of a GM vehicle that ran a 24x crank reluctor with 6 cylinders? You may be able to take an existing V8 file and rewrite it to be a six.
    Al
    Mar 2007
    I believe the Astro 4.3 up to 2005 uses the 411 ECU so does anyone have a factory tune that I can look at? Im not sure if I Can write the LS1 411 ECU to 6 cylinder?
    You can write an Astro van or S10 tune to the 411 PCM but it uses a combination of a 3x crank reluctor and high voltage switch ( distributor) with an integral cam sensor. Setting up the distributor would likely be a tough project.
    Al
    Mar 2007
    OK I assumed the 411 would be 24 tooth, so I need to get by hands on a distributer and see how it works, Thanks for the information. Has anyone got the pinouts for the V6 411 ecu?
    Mike
    Mar 2007
    Quote Originally Posted by ChipsByAl View Post
    Al
    So its possible to take the V8 file and make it into a V6?
  1. 411 ecu with 98 Vette pedal tac and ls2 tbody issues
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: April 23rd, 2018, 08:33 AM
  2. Base tune for l92 on ls1 loom/ecu 4l60e
    By gareth12 in forum Gen III V8 Specific
    Last Post: January 11th, 2018, 08:35 AM
  3. Questions about putting a 411 ECU on a Gen 1 SBC
    By Jim in forum Gen III V8 Specific
    Last Post: February 1st, 2017, 06:41 PM
  4. Replies: 0
    Last Post: May 30th, 2014, 10:59 AM
  5. need cos3 tune file for 411 swap
    Last Post: April 6th, 2011, 01:40 AM
