Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Tuning/68rfe questions
  1. #21
    Jul 2024
    Quote Originally Posted by Jim P View Post
    Pressure increase is only for tighter clamping pressure on clutches, it’s not gonna do anything for shift speed, that’s a whole other hidden realm in parameters but you can bump up pressure to 170psi and be fine.
    That seems conservative enough for me. Just 10psi over stock. Thanks for your help Jim!
  2. #22
    Senior Member Jim P's Avatar
    Nov 2019
    Yeah I wouldn’t go anymore than that otherwise you will get into the realm of getting fractures in the valve body
  3. #23
    Jul 2024
    For later shifts you only need to raise the upshift cells till it shifts when you want it to. It uses a factor of 32 so whatever number you put in for output shaft rpm should be evenly divisible by 32, anything in between doesn’t exist.
    Was thinking of something like this to start. Eliminating that flat section so it will downshift with less pedal input.
Name:	Screenshot (3456).png
  4. #24
    Nov 2019
    Downshift tables for downshift, just make sure it doesn’t overlap into the upshifts or it’ll get weird
  5. #25
    Nov 2019
    What you see in EFILive and hp tuners for transmission parameters is barely scratching the surface of what’s really in there, would be lost for months if you seen it all lol
  6. #26
    Jul 2024
    I get it. The amount of hexadecimal addresses Dyno Spectrum mapped on C7 Audi is mind boggling yet they haven't scratched the surface of what the crazy Germans programmed.
    Jim are you an EFI dealer?
  7. #27
    Nov 2019
    No im not an EFILive dealer, I do sell tuning on occasion and reverse engineer the Cummins/chrysler code and modify the code when I got some spare time, which has been very little spare time for awhile now. Too many other priorities.
  8. #28
    Nov 2019
    Will see, maybe soon here I can get some more focus back into the coding and start making some progress again towards my ultimate goal with it
  9. #29
    Jul 2024
    We should talk offline about my needs and if that's something you're willing/able to provide. Shoot me an email to the address above.
  1. Dyno Tuning RAM 2500 68RFE
    By Truck-Tuning in forum Cummins 6.7L
    Last Post: March 28th, 2023, 09:59 PM
  2. 68rfe tuning
    By catman3126 in forum Cummins 6.7L
    Last Post: December 6th, 2021, 11:59 AM
  3. Learning 68RFE tuning
    By 20172500 in forum Cummins 6.7L
    Last Post: April 6th, 2021, 08:11 AM
  4. 2012 68RFE Tuning over someone elses tune ?
    By staytuned in forum Cummins 6.7L
    Last Post: July 25th, 2017, 05:38 PM
  5. 68rfe tuning
    By DieselMafialb7 in forum Cummins 6.7L
    Last Post: November 26th, 2014, 01:42 AM
