Results 1 to 7 of 7
Thread: Help Making a map
    Default Help Making a map
    I was trying to use calc.ve followed all the setup,
    problem 1 cannot seem to get my WB showing up in the 7.5 scanner I think that is needed for calc.ve to work
    so can someone help me make a map that uses ltft plus stft to get an error/correction amount to apply to the tune file
    Mark
    Have you tried V8 software? Its pretty easy to do maps in it.
    I started playing with v8 friday, i will play more with it next week
    Mark
    Which ECM/PCM are you messing with?
    Quote Originally Posted by nonnieselman View Post
    LS1B 2001 GMC Silverado 8.1L
    Mark
    Use a spreadsheet or a tuning tool that supports calc.ve to process these logs and adjust the VE table accordingly.
    Quote Originally Posted by seniorhurt View Post
    Got more info?
  1. Making a .bin
    By Snipesy in forum General (Diesel)
    Last Post: November 24th, 2016, 04:42 PM
  2. making tunes
    By lp14255 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2014, 02:17 PM
  3. Making PIDS
    By minytrker in forum General
    Last Post: October 16th, 2009, 05:13 AM
  4. Map making question...........
    By FreddyG in forum Gen III V8 Specific
    Last Post: November 15th, 2007, 11:06 AM
  5. Making an external MAP input device, need data!
    By Redline Motorsports in forum General
    Last Post: November 9th, 2007, 09:54 PM
