Results 1 to 3 of 3
Thread: OS change
    Default OS change
    Is there a way to change VIN or OS on an E38 PCM, I've got a bunch of early 07-08 E38 PCM's that are worthless because they hit the P/N Rev limiter No matter what I do in the cal because I'm trying to use them on Manual setups.
    Quote Originally Posted by Schwanke Engines View Post
    You can change the VIN using the VIN change option:
    You can change the OS with another compatible OS if you perform a full-flash.
    Compatible OSes can be looked up like this:
    Jul 2003
    post the file.
  1. i want to change os
    By Mr Drescher in forum Gen III V8 Specific
    Last Post: April 28th, 2016, 12:47 PM
  2. 6.7 OS change
    By royalflush in forum Cummins 6.7L
    Last Post: November 12th, 2013, 02:58 PM
  3. What to change and how to change
    By gigabrock in forum Duramax LB7
    Last Post: July 20th, 2012, 03:52 AM
  4. change os or not and how to do it?
    By rennat_2006 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 9th, 2011, 06:36 PM
  5. HELP! cant change the OS`s over how do I do it?
    By LuthurUbU in forum General (Diesel)
    Last Post: September 3rd, 2009, 07:53 AM
