Results 1 to 7 of 7
Thread: P0300 / Tuning Mystery
    Jun 2009
    Default P0300 / Tuning Mystery
    Need a little help on this. Primarily rough idle and occasional surging to light throttle issue, sets the P0300 code even after increasing values in C5621. No expert but, looking at the log, seems like something is up with the O2 sensor system.
    6.0L in a Yukon XL, small cam (-2 degree overlap), 823 heads, TBSS intake, SEP injectors (with their tune data), stock exhaust...
    To this point:
    - New MAF and front O2 sensors
    - New plugs and wires, good spark, plugs look good/all the same
    - New fuel pump, filter, etc., adj FPR, fuel pressure checks good
    - Noid light check on injectors
    - Good compression
    - Smoke check - no apparent vacuum leak
    - I've reduced the idle spark overspeed/underspeed compensation B5935/6
    - Desired Airflow, VE, and MAF frequency are as close as I can get them
    Check the crazy voltage readings on the O2 sensors (WB at location 11). I figure it's normal for the WB to read about 450mv steady?
    I've suppressed the secondary 02 sensor DTCs and figure the CATs have lost effectiveness but the performance is so good, it doesn't seem like they could be clogged.
    IF WB is steady 450mv it is either bad or disconnected.
    What are cam specs?
    Jun 2009
    Update: Desired airflow was off a little, idles much better now. Logged misfires and even though the P0300 code is not being tripped, it's significant enough to unlock the converter. Cyl 1, 2, and 3 are the primary culprits, 2 & 3 are the worst. The log was recorded at 60ish MPH cruise. The converter locks, then as the misfires build (which you can feel), it unlocks.
    In one very specific circumstance, the Check Eng light will flash - hwy speed, very light load, as you slow or reduce throttle to maintain speed down slight incline (single digit TPS). Again, no P0300 in this case, nothing in memory.
    Cam: 212/212 .553" 107 LSA +3
    Readout on WB and data in log looked good and seemed accurate as I did some tests with injector flow rates and saw exactly what you would expect.
    Jun 2009
    Default Log file
    Log file for cruise 60 mph
    Aug 2013
    Some aftermarket injectors perform poorly in low pulse, which is where you seem to be having problems. Try swapping injectors 1-4 with 5-8 and see if the misfires follow the injectors.
    Jun 2009
    Good call on the injectors, I'm afraid that might be it. Will do the swap then the same with coils if the injectors check OK.
    Thanks.
    Jun 2009
    Looks like it's the injectors. Coil test passed.
    Misfire followed the injector and misfires pick up on the three suspect cylinders as PW drops close to 2 ms. Min injector PW is .76 so, that's disappointing.
    Per data from SEP, Small Pulse Adjust does not kick in (zeros) until PW gets down to 1.033ms.
    I set Default Minimum Pulse Width to the same as Min Injector PW (.76), didn't know what else to set.
    Also, I left Small Pulse Threshold alone at 4.0ms.
    Just hoping there's something in the tune that can be adjusted...
  1. Help with 5 position mystery switch
    By meanpeace in forum General
    Last Post: April 9th, 2016, 09:37 AM
  2. IAT mystery
    By frdstang93 in forum Gen III V8 Specific
    Last Post: October 30th, 2013, 05:45 AM
  3. p0300 help
    By Gregs in forum General
    Last Post: February 3rd, 2012, 04:42 PM
  4. LMM: working a mystery
    Last Post: February 7th, 2010, 11:28 AM
  5. Mystery Misfire codes?
    By Mr. P. in forum Gen III V8 Specific
    Last Post: November 5th, 2009, 04:46 AM
