Results 1 to 4 of 4
Thread: Oct 03, 2024, V8.4.62 Beta Release - Update 5
    Default Oct 03, 2024, V8.4.62 Beta Release - Update 5
    V8.4.62 Public Beta Release - Update 5
    Be careful when installing the beta software on your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. If you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta software on a separate PC, laptop or virtual machine.
    WARNING for all users:
    Tune files saved using the beta software are not backwardly compatible with previous versions of the EFILive software.
    Tune files saved using previous versions of the EFILive software are compatible with this beta version.
    The method for calling Lua scripts from custom menus has changed, please see
    \Documents\EFILive\V8\User Defined Menus\SampleCustomMenu.txt for more info.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.4.62
    • FlashScan/AutoCal V3 Firmware: V3.00.133
    • FlashScan/AutoCal V2 Firmware: V2.08.212
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    So I get this error when trying to open calibrations that I have user defined Cax8 files with.
Name:	Cax8 error.png
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Quote Originally Posted by dansdieselp View Post
    So I get this error when trying to open calibrations that I have user defined Cax8 files with.Click image for larger version.
    Can you send me the *.cax8 file that is giving that error? Send it directly to me at paul@efilive.com
    Apr 2009
    Disregard. Wasn't aware the V3 firmware had to match in order for it to work.
  1. Sep 08, 2024, V8.4.61 Beta Release - Update 4
    Last Post: 3 Weeks Ago, 08:50 AM
  2. Aug 28, 2024, V8.4.60 Beta Release - Update 3
    Last Post: 4 Weeks Ago, 05:30 PM
  3. Aug 25, 2024, V8.4.59 Beta Release - Update 2
    Last Post: August 27th, 2024, 09:47 AM
  4. Apr 13, 2024, V8.4.51 Beta Release
    Last Post: April 26th, 2024, 04:42 PM
  5. Apr 11, 2024, V8.4.50 Beta Release
    Last Post: April 12th, 2024, 10:03 AM
