Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: P0300 / Tuning Mystery
    Jun 2009
    Also, for anyone that reads this in the future, the tune has B9021 cax loaded, and the suspect injectors still misfire with B4003, and B4004 set to .015198.
    Quote Originally Posted by robof16 View Post
    50 lb/hr at 43.5 psi?
    50@58psi
    Jun 2009
    Thanks. No harm in trying the injectors you suggest. PM sent.
    Where do you purchase injectors if you need more flow?
    Fuel Injector Connection.
    What kinda FI are you thinking? How much power?
    Those "3412" injectors can flow enough for 5-6psi from a decent size turbo.
    Ive used these in several turbo trucks over the years.
    https://fuelinjectorconnection.com/p...pters-set-of-8
    Jun 2009
    Turbo - The 3412's and 5-6psi is a great place to start and the FIC 72's will be perfect if I turn it up.
    Thanks for your help.
    Jun 2009
    To close this out, the injectors were the culprit - couldn't handle the low pulse widths. Clues were that the misfires were only at idle and light throttle and, that the misfires followed the injectors. Only 3 out of the 8 injectors had the problem.
  1. Help with 5 position mystery switch
    By meanpeace in forum General
    Last Post: April 9th, 2016, 09:37 AM
  2. IAT mystery
    By frdstang93 in forum Gen III V8 Specific
    Last Post: October 30th, 2013, 05:45 AM
  3. p0300 help
    By Gregs in forum General
    Last Post: February 3rd, 2012, 04:42 PM
  4. LMM: working a mystery
    Last Post: February 7th, 2010, 11:28 AM
  5. Mystery Misfire codes?
    By Mr. P. in forum Gen III V8 Specific
    Last Post: November 5th, 2009, 04:46 AM
