Results 1 to 8 of 8
Thread: LBZ TCM Tune
    Oct 2024
    Default LBZ TCM Tune
    Hi I have a Nissan GU Patrol Duramax LBZ conversion with Allison 6sp
    I have the T14A TCM can this be tuned ?
    Just making sure this is correct TCM part number 24256864
    Oct 2024
    Or is A40 better TCM ?
    I don't know that there are any calibrations for a T14 and LBZ.... Could be, I suppose. But A40 is a safer bet for calibrations for a LBZ.
    Oct 2024
    T14A. T14 is equivalent to A50 TCM Cheers
    Quote Originally Posted by Sydo View Post
    Well, yes, the A40, A50 and T15 are all 'basically' the same, but they may never have made a calibration for the T14 for it to work right with an E36A/LBZ ECM. The LBZ only ever had the A40 as far as I know, the A50 came out for late LMM or early LML, and then the T14 came out, before being replaced with the T87 in the 2015.5 LML.
    Now if that T14 came with the LBZ and has the proper calibration to work with the E35A, then just roll with it.
    Edit: it does look like there is a LBZ calibration for that 24256864 hardware, so if it has the right calibration in it. (Or if it doesn't and you can program it), I'd just roll with it.
    Oct 2024
    Thanks mate. Just got this reply from EFI Live
    Keep in mind that generally, there isn't much to be gained by tuning the Allison TCM. Other than maybe changing shift points, the consensus I've gathered over the years from those more knowledge than me in tuning is to leave the TCM alone.
    Oct 2024
    Just found out when I plugged in scan tool comes up with 2009 LMM Sierra ECM and I have a LBZ Engine
  1. lbz tcm issues
    By Boosted Duramax performan in forum Allison 5 & 6 Speed
    Last Post: January 23rd, 2018, 12:08 PM
  2. tcm read issues on lbz/lmm
    By smudge122 in forum FlashScan V2
    Last Post: July 4th, 2012, 05:36 AM
  3. cant read 2006 lbz allison tcm
    By mrrattle in forum FlashScan V2 BB Logging
    Last Post: February 27th, 2008, 04:31 PM
  4. 06 LBZ PCM and TCM question
    By SSTuner in forum General (Diesel)
    Last Post: November 4th, 2006, 12:27 AM
