Thread: XDF to CAX Converter
    Sep 2013
    Default XDF to CAX Converter
    Over the past few months, I have been building a converter to convert definitions from TunerPro XDF format in to the EFILive CAX format.
    I have now published it, and is free for use.
    converter.twinrivertuning.ca
    I'm always trying to update this and add new support.
    If you run in to issues or find something that could be added, please post it here.
    Sep 2013
    Change Notes
    v0.4
    XDF min / max now supported. Hard min / max will override soft limits if exceeded.
    Fixed issue with column first tables transferring as unsigned.
    TunerPro units are now supported.
    Known Bugs
    v0.3
    Another fix for the issue with 32 bit floats being converted to 32 bit unsigned.
    v0.2
    Fixed 32 bit floats being converted to 32 bit unsigned.
    Spaces in table labels now convert with an underscore, fixing a bug in how tables are displayed.
    v0.1
    Initial release
    Known Bugs
    Factor and offset are in beta testing. -> Decimals and basic functions work as intended. Scientific notation can be buggy.
    EFILive populates tables by Row / Column based on controller. TunerPro is not this intelligent, as it has no controller reference. If your tables do not transfer properly, the XDF may need to be changed between Row / Column.
    Mar 2022
    Thanks a lot for this tool. It works great for the most part.
    One little issue I noticed was when converting a floating point definition, the converter sets it to UNM in the CAX rather than FLT.
    Sep 2013
    Quote Originally Posted by Lennydmaxguy View Post
    Thanks for the feedback. I found the culprit, so I'll get it fixed on the next release.
    I was also informed of a bug on table labels. I neglected to take in to account that spaces are treated like commas in a CAX file. This will be fixed on the next release as well.
    Sep 2013
    v0.3 released. Both bugs should now be fixed.
    Sep 2013
    v0.4 released.
    Bug fix, TunerPro units supported, XDF limits supported.
  1. CM2350B A2L, XDF or Damos
    By ManyLiters in forum Cummins 6.7L
    Last Post: December 19th, 2021, 09:50 AM
  2. converter slip
    By crash85 in forum Allison 5 & 6 Speed
    Last Post: May 16th, 2011, 08:50 AM
  3. converter problems
    By pullincrazy88 in forum Allison 5 & 6 Speed
    Last Post: May 15th, 2009, 11:46 PM
  4. Torque Converter?
    By Bradazz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2007, 12:28 AM
  5. Stall converter
    By Chevvy SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 30th, 2006, 07:37 PM
