Results 1 to 2 of 2
Thread: Oct 12, 2024, V8.4.63 - Release Candidate 1
    Default Oct 12, 2024, V8.4.63 - Release Candidate 1
    V8.4.63 Release Candidate 1
    WARNING for all users:
    Tune files saved using the beta software are not backwardly compatible with previous versions of the EFILive software.
    Tune files saved using previous versions of the EFILive software are compatible with this beta version.
    The method for calling Lua scripts from custom menus has changed, please see
    \Documents\EFILive\V8\User Defined Menus\SampleCustomMenu.txt for more info.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.4.63
    • FlashScan/AutoCal V3 Firmware: V3.00.134
    • FlashScan/AutoCal V2 Firmware: V2.08.212
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    Issue #1: Serial wide-band data is not being detected/recorded by V3 devices.
    Workaround: Update to firmware version V3.00.134(3) by clicking on this link. You will need to use EFILive Explorer to update the firmware if your device already has firmware V3.00.134 installed.
    Regards,
    The EFILive Team
  1. Oct 03, 2024, V8.4.62 Beta Release - Update 5
    Last Post: 3 Weeks Ago, 10:58 AM
  2. May 05, 2024, V8.4.53 Release Candidate 2
    Last Post: May 19th, 2024, 02:10 PM
  3. Apr 27, 2024, V8.4.52 Release Candidate 1
    Last Post: May 4th, 2024, 05:28 PM
  4. Mar 23, 2024, V8.4.48 Beta Release
    Last Post: April 6th, 2024, 11:47 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 08:17 AM
