Results 1 to 3 of 3
Thread: Oct 27, 2024, V8.4.64 - Release Candidate 2
    Default Oct 27, 2024, V8.4.64 - Release Candidate 2
    V8.4.64 Release Candidate 2
    WARNING for all users:
    Tune files saved using this release candidate software are not backwardly compatible with previous public release versions of the EFILive software.
    Tune files saved using previous versions of the EFILive software are compatible with this beta version.
    The method for calling Lua scripts from custom menus has changed, please see
    \Documents\EFILive\V8\User Defined Menus\SampleCustomMenu.txt for more info.
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.4.64
    • FlashScan/AutoCal V3 Firmware: V3.00.135
    • FlashScan/AutoCal V2 Firmware: V2.08.212
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Workaround: Ignore unsupported DMA PIDs.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    Oct 2024
    Greetings! I started using EfiLive and get a trouble.
    On a pc with Win11 pro get this error while opening any graphical map,
    on other pc with Win10 pro all ok. Please help.
    Sorry maybe writing in wrong section of the forum.
Name:	New Bitmap image.jpg
    That error occurs if/when your graphics card driver is not up to date or does not or cannot support OpenGL 3D Hardware acceleration.
    EFILive recommends updating the drivers for your graphics card if possible. Otherwise you'll need to use a different PC/laptop with a more modern graphics card/chip set. Maybe even just updating your Windows operating system the latest available version may help.
    You can look in the EFILive V8 "About Screen" to see what the OpenGL support is on your PC/laptop - that may help you figure out what graphics card vendor you need to download updated drivers from.
    For example on my system here the graphics card vendor is NVIDIA, so I would need to go to NVIDIA's web site to get the latest drivers for my system. Yours will probably be different.
  1. Oct 12, 2024, V8.4.63 - Release Candidate 1
    Last Post: 1 Day Ago, 01:30 PM
  2. Oct 03, 2024, V8.4.62 Beta Release - Update 5
    Last Post: 3 Weeks Ago, 10:58 AM
  3. May 05, 2024, V8.4.53 Release Candidate 2
    Last Post: May 19th, 2024, 02:10 PM
  4. Apr 27, 2024, V8.4.52 Release Candidate 1
    Last Post: May 4th, 2024, 05:28 PM
  5. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 08:17 AM
