Results 1 to 3 of 3
Thread: AutoCal file loading for old device
    Nov 2024
    Default AutoCal file loading for old device
    My brother has a low mileage 2007 Duramax and uses the tuner shown in the pictures below. I used to have the software to load files onto the device, however that was a few laptops ago.
    Is it possible to acquire the software to be able to load some additional tune files to this device. I know it is old but thought it may be worth a try. Thank you for an insight.
    That is a Autocal and it is linked to a Flashscan V2 interface box. Whoever he bought the Autocal from will be able to load files for you.
    Nov 2024
    Thank you for the reply. I was able to load the file to the device by using EFILive V8 explorer. Adding the file gave me a total of four files. However, when connecting to the device it wanted me to update the firmware of the AutoCal device from 2.07.027 to 2.08.009 a newer version. In doing so none of the files will now load to the vehicle, it has an error code. Could this be that the files I have were created to work with the older version of firmware? Would I now need the tuner to update the tune files to be compatible to the newer firmware of the device?
    Thank You for any insight.
  1. AutoCal error when loading tunes.
    By LPDTuning in forum AutoCal
    Last Post: July 20th, 2017, 01:20 AM
  2. Loading a tune to my autocal (2014 Cummins)
    By yamaharider529 in forum General
    Last Post: January 2nd, 2016, 10:06 AM
  3. Autocal bootblock/firmware upgrade bricked the device
    By nativesun1979 in forum AutoCal
    Last Post: December 4th, 2013, 04:41 AM
  4. Code 0536 tune file not registerd to autocal device
    By manny sts v in forum AutoCal
    Last Post: January 10th, 2013, 10:47 AM
  5. Autocal Tune Loading Issues
    By boaty3 in forum AutoCal
    Last Post: March 20th, 2012, 10:23 PM
