Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: New 2023 engine in a 2020 RAM 3500 with Aisin but 2020 ecm (Can someone help me)
    Sep 2024
    Remember that the ECM is blank right now, I think they will program it in the next few days because they made a lot of progress today, they are already installing the entire interior, and the engine and transmission are installed, there are still a few details missing, fuse box, some harnesses, etc. I will be with the programmer when he does it. Or do you want me to tell you the exact details of the calibration, ecm code etc, when he finishes?
    Senior Member Jim P's Avatar
    Nov 2019
    Just tell him to program it with a 2021 pickup aisin calibration. Don’t know what he’s using to do it but he should be able to program whatever calibration he wants to it
    Sep 2024
    I think he uses Witech. I'm going to tell you about the 2021 calibration with my Transmission. Because in 2021 the pump is already updated, right?
    Sep 2024
    Normally in Cummins Heavy Trucks I can change parameters that I need with Calterm directly connected to the truck or some with Insite and you know that with Calterm I can get the calibration of the ECM and make the modifications that I need, but I know that with this it does not work like that, I have never really connected to any, In these how can I get the calibration after it is programmed? Can I change any parameter directly connected to the truck?
    Nov 2019
    You can change them like that, will not stick though. ECM powers down those changes are lost.
    Nov 2019
    And yes the 2021 calibrations is when they went back to the CP3
    Sep 2024
    Perfect, I'll do that, I called him now and he said yes, he uses the Witech and he may be able to put the 2021 calibration on it. After that, and I verified that it starts and everything is fine, I want to do the other thing that you know. Thanks a lot for the help and advice Jim. How can I read the calibration of this ECM? I would like to read it and save it in case I want to make any modifications in the future.
    Nov 2019
    You can use Calterm to read it, don’t think it’ll give you a readout the alter and flash back in though and if you don’t have the config files needed, won’t make a difference anyways as it won’t open the readout. You can read it with hp tuners and use that but at higher risk of bricking the ecm just from reading it alone and tune with hp tuners or there are EFILive tune files on the forum to use to tune.
  9. #19
    Sep 2024
    Okay. Thanks Jim. So the best option would be to look for a Tune File for Efilive 2021 with my Aisin transmission and Manual Transfer Case? Is there a number or something specific I need to look for the Tune File After they program it for me, stock ?
  1. 2020 cm2450b/aisin stock tune file
    By karch_13 in forum Cummins 6.7L
    Last Post: 2 Weeks Ago, 01:23 PM
  2. 13-18 Ram 3500 4x4 Aisin Stock Tune
    By samuser21 in forum Cummins 6.7L
    Last Post: July 26th, 2024, 11:06 PM
  3. 2018 Ram 3500 SRW Aisin TCM factory file.
    By gemcityfireman in forum General (Diesel)
    Last Post: December 12th, 2023, 08:54 AM
  4. Replies: 7
    Last Post: October 23rd, 2022, 04:05 PM
  5. 2020 brazilian ram 2500
    By romulo_sampaio in forum Cummins 6.7L
    Last Post: January 9th, 2020, 08:59 AM
