Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Autocal V3 With L5p Duramax
    Dec 2024
    Default Autocal V3 With L5p Duramax
    I have a 2018 L5P duramax 2500HD
    i had purchased the Autocal V3, does anyone do custom tunes with the autocal V3, i just sent back my edge evolution tuner in hopes i can get a tuner that supports a DEF delete. i want a tuner that supports it so when i decide to do the delete i don't have the worry about a tuner or anything like that. i can just have someone send me a tune and ill be good, but right now it is fully stock and just would like an economy tune. and an option to switch to a deleted tune after i proceed to that. i have looked all over and cant find anyone who does custom tunes with the efilive products with this truck. can anyone point me in the right direction? if i get the Flash scan will that allow me to just slightly tweak the stock file without being overly complicated? do i need the flash scan and autocal v3 both to tune my truck my self or can i just use a flash scan if i sent this autocal back?
    Jun 2022
    To make changes by yourself you need a Flashscan not an Autocal. The tough part is going to be finding a stock file as you cannot read your stock file through the OBD Port. Not to mention the unlock process. Good luck in your endeavors. EFILive L5P support is not openly talked about from what I have seen.
    2016 LML
    Dec 2024
    I have the ecm already unlocked by the edge ecm unlock tool. So i got that done but yeah like you said the stock file would be hard to find
    You will have to be sneaky and speak lightly on the whole Delete tune deal.
    Dec 2024
    Yeah, i didnt realize how hard it would be to just change/tweak some settings on an l5p duramax. Is a delete possible on hp tuners? I heard they dont support deletes but i also see plenty of people having custom tunes for the l5p with hp tuners. Im just kinda stuck right now unsure if there is a tuner that supports a delete and is able to do normal tunes with emissions intact, so if i want to do the delete down the road i have a tuner that will do that when i want it too. But i understand the whole lawsuit thing which i also thought was now legal and fine to do? I don't want to spend $1000 on a tuner that is only for emissions intact, then another $700 on one thats for a deleted truck, is there a tuner that is able to do both? Ive heard of ez link and efilive but efilive nobody does the tunes for l5p and seems impossible to do what i need to do.
    EFI Live and HPTuners dont support the remove of the Emission settings in the tune. But there are ways to do stuff.
    Ive used EZLynk on some F250s and it will do Tunes for emissions intact and other settings all from your cell phone.
    Sep 2013
    No tuning suite will do emissions deletes on newer trucks. Hard stop, end of story.
    If you would like to do anything outside of what is offered, you need custom definition files to expose those parameters.
    Quote Originally Posted by Omega_5 View Post
    And thats where the money is...
    Dec 2024
    Can you explain what that is? Or know where to get them? I been looking at tuner depot, looks like they got a delete tuner, can i not just get a delete tune from someone to open those parameters?
    Sep 2013
    Quote Originally Posted by Aftmost View Post
    In EFILive terms, a custom definition is a CAX or CAX8 file.
    They expose parameters that aren't defined by EFILive. EFILive has official documentation on how to use them.
    Having a certain tune doesn't expose parameters. They are set and not shown to you.
    Without being offensive, if you are looking at TunerDepot you are probably getting a bit over your head with custom parameters.
    Quote Originally Posted by nonnieselman View Post
    Not sure the intent of the comment, but I'll bite.
    People invest hundreds of hours (maybe more) in to finding certain things. In some cases there is a capital investment in hardware or software as well.
    Is there some expectation that those definitions should be freely available for everyone else to make money off of?
  1. L5P E41 stock file
    By Yaboy131 in forum General (Diesel)
    Last Post: December 23rd, 2024, 10:26 PM
  2. L5P Support soon?
    By TorqueMonster007 in forum General (Diesel)
    Last Post: May 25th, 2023, 08:45 AM
  3. L5P beta tester?
    By duramaximizer in forum General
    Last Post: February 15th, 2022, 01:06 PM
  4. hmmmmmmmmmmmmmm.........bad news for L5P
    By GMC-2002-Dmax in forum Diesel
    Last Post: April 16th, 2018, 09:38 AM
Tags for this Thread
