Page 7 of 37 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 364
Thread: Custom OS#5
  1. #61
    Hmmm... sounds like too much fun, I'll have to give it a whirl...
  2. #62
    Dec 2004
    I don't know if you need a big cam to take advantage of TPS vs VE Mult feature but I believe my baby cammed LS1 needs this table:
    Case in point
    My car bucks badly at around 1600rpm in 5th at cruise when constantly on and off the throttle at light inputs. I reduce the VE table b/w 1600-2000rpm by 2%. Bucking stops. But engine pings at moderate %TPS. I have to take a serious chunk of timing out (6*) between 1600-2000rpm to stop the pinging. No more bucking and no more pinging. However, the problem is that I've lost that effortless overtaking capability because I've lost timing. The only way I can restore the timing is to richen the mixture but then I'll re-introduce the dreaded bucking... which is why I badly need the TPS vs VE Mult table.
    Can't wait to try it!
  3. #63
    The one problem this does have is in an A4 transitioning in and out of Drive, there is no detected load change for the VE, however that also has an advantage too because the fueling remains constant and the spark / IAC handles the RPM drop.
    I ran this in my car for about a month a while back, and given plenty of logging time for BEN factors you can get the AFR's so spot on you'd think the WBO2 was stuck!
  4. #64
    Oct 2005
    SSB, check your base spark and high octane spark. If they are way different at the points you mention try closing the gap, seemed to help for me with a similar problem when hardly using throttle at low speed.
    2008 Z06 C6 Corvette
  5. #65
    Oct 2004
    I'm now running on OS5 as well. Just cause I can really, more than really needing it
    But I have a question.. Where is, or what is/was OS4? How did we arrive at 5?
    And now onto mapping the TPS VE Table
    Is there any guidance on what settings should be used for the RPM, MAP and TP exit points?
    Andrew
    EFILive Crew
  6. #66
    Quote Originally Posted by Tordne
    V4 was going to be the N20 options only, but in the end it was possible to squeeze everything in to one O.S, though, on the later 2004+ O.S's this might not be possible. There is a few cars in Aus running O.S #4, it's been out for a long time, but these were only used by workshops for N2O cars only.
    I had to a custom O.S #3 for a 2006 Hummer and that was pretty much full up so I am not sure how far we can go!.
    Besides, nearly all 2003+ O.S' are used on ETC applications, I am not sure the TPS VE table would work too well on them.
  7. #67
    Oct 2005
    Never mind, lets us old skool pcm and tb guys have one up on the jones's.
  8. #68
    Bragging rights.
  9. #69
    Oct 2004
    So I have managed to map a reasonable portion of what will be the TPS VE Table. I have filled in the blanks and have basically got what I think is a reasonable first cut at this table.
    So, the next test is to go and drive it. I have set all TPS VE Table disablers high, so that it will run exclusively from the TPS VE Table.
    I have also made a MAP that will represent the BEN factor for the table to allow for correction (or at least that is the plan).
    I'll probably give this a go in the next little while (gently ) and then if all is looking OK might even drive it home like that
    This is all very exciting
    Andrew
    EFILive Crew
  10. #70
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    I'll be online here in a bit to help you out on it. I would add a little to your TPS table that you have plotted to ensure it isn't lean.
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
