Results 1 to 3 of 3
Thread: FRP%Commanded is opposite of Desired Pressure
    Jun 2012
    Post FRP%Commanded is opposite of Desired Pressure
    07.5 LMM (Losing My Mind / Less Money Monthly) with chronic P0087. Have been through the physical checks, finally noticed the FRP commanded % decreases (along with the rail pressure) whenever I step on the throttle. At WOT, its at 11 or 12% and the rail pressure is missing 10K PSI. Isn't the commanded % supposed to follow the Desired Rail Pressure? The TPS PID wasn't working, but when the APP_ PID shows 84%, thats my foot all the way to the floor. If anyone has some insight on this, I'd be very thankful!
    Happy New Year!
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Lower duty cycle = higher pressure. An unplugged FCA causes the cp3 to make full pressure, which will vary with RPM
    Sent from my Pixel 4a using Tapatalk
    2010 Dodge QCSB 6.7 Auto
    Jun 2012
    Quote Originally Posted by WyoFreeride View Post
    Ah, ok... so by unplugging the FCA, the duty cycle would become 0%, calling for full pressure? Guess I need to run more logs.
  1. Max desired fuel pressure table?
    By danny68ss in forum Petrol / Gas
    Last Post: November 2nd, 2023, 04:19 PM
  2. LBZ E35A seems to be in limp mode!!! FRP and lift pump pressure check out, no CEL!!!
    By Singhindiesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 29th, 2023, 07:32 AM
  3. What determines Fuel Pressure Desired?
    By EverydayDiesel in forum Cummins 6.7L
    Last Post: November 29th, 2017, 09:27 AM
  4. b1010 vs actual frp and big pressure loss
    By relentless addiction in forum Diesel
    Last Post: July 7th, 2014, 01:41 PM
  5. B0720-FRP: actual or desired?
    Last Post: November 11th, 2009, 05:55 AM
Tags for this Thread
