Results 1 to 8 of 8
Thread: New injectors, can efi live program the new numbers in
    Feb 2025
    Default New injectors, can efi live program the new numbers in
    I looked everywhere but came up empty.
    Thanks,
    Mac
    Quote Originally Posted by macr88 View Post
    Thanks,
    Mac
    What injectors did you buy?
    They should have come with data that you put into your tune and your good to go.
    Feb 2025
    I can’t figure out where the numbers go in efi live. The numbers are on top of the injectors and they’re just stock.
    Woops. I thought this was in the gas burner section.
    If they are stock injectors why are you needing to change anything?
    Mar 2022
    Each injector has an individual flow rate number. AFAIK Efilive can't program that. You'll need a scan tool to do it. Any good aftermarket tool can do it.
    Feb 2025
    Quote Originally Posted by Lennydmaxguy View Post
    Yea, I couldn’t find anything on here or in efiLive regarding it so I ordered up a scan tool. Kinda of a shame it can’t do that.
    Thanks ��
    if it makes you feel any better. i tuned a conversion for someone recently with an e98 ecu that did not come with the motor & it worked fine. no injector faults or issues.
    Feb 2025
    You may get lucky and not have any faults but it’s not optimal. Probably isn’t running as smooth as it could.
  1. Replies: 16
    Last Post: June 14th, 2016, 04:24 AM
  2. Calibrating injectors to ecm with efi live?
    By bt2715 in forum Tutorials
    Last Post: January 25th, 2015, 08:41 AM
  3. Replies: 10
    Last Post: December 26th, 2011, 08:44 PM
  4. Can You Use Efi Live to Program Remote Entry?
    By Mitco39 in forum FlashScan V2
    Last Post: January 21st, 2009, 03:28 PM
  5. Efi Tune Working But Scan Program Is Not?!?
    By Coker6303 in forum General
    Last Post: July 31st, 2008, 02:25 AM
Tags for this Thread
