I looked everywhere but came up empty.
Thanks,
Mac
Thanks,
Mac
I can’t figure out where the numbers go in efi live. The numbers are on top of the injectors and they’re just stock.
Woops. I thought this was in the gas burner section.
If they are stock injectors why are you needing to change anything?
Each injector has an individual flow rate number. AFAIK Efilive can't program that. You'll need a scan tool to do it. Any good aftermarket tool can do it.
if it makes you feel any better. i tuned a conversion for someone recently with an e98 ecu that did not come with the motor & it worked fine. no injector faults or issues.
You may get lucky and not have any faults but it’s not optimal. Probably isn’t running as smooth as it could.
