Results 1 to 10 of 13
Thread: Odd spark behavior in SD
    Jun 2009
    Default Odd spark behavior in SD
    I have concurrently developed the same tune to run CL with MAF and OLSD (DTC confirmed) and have noticed significant erratic spark behavior in SD not present with the MAF-enabled version. It is very apparent in the logs and while driving. I first noticed under high load, the SD tune selecting lower spark values as if pulling from the low-octane table but ASPARK is 100% for BOTH in the logs under the same conditions. Now, I see it is happening in all conditions. As a result, the CL tune feels smoother, especially under load and pulls harder because the spark is consistently following the high-octane table.
    The photo shows a short SD log and just after frame 1150 you can see where the anomaly starts. This is the first time I’ve seen it change from smooth to erratic. It is so significant in light load situations like the one just after frame 1610 that it feels like a misfire.
Name:	SD spark.jpg
    Try to copy Hi octane table to low octane table.
    Jun 2009
    I really didn't want to do that so, I thought, what if I switched the MAF DTC's from Non Emissions to Not Reported? It seems to have worked.
    Jun 2009
    2nd SD log with no spark issues... Looks like it's fixed.
    Quote Originally Posted by robof16 View Post
    It was just a test.
    Jun 2009
    oh... Cpy.
    Thanks for the replies.
    Jun 2009
    Since it changed during the posted log, as the truck warmed up, I thought it could be ECT related but apparently not.
    I dont see a log that was posted.
    Jun 2009
    I meant the photo attached to the original post
    Its hard to look at a picture of a log. Uploading it helps a bunch.
  1. Odd, very odd but entertaining nonetheless
    By Doc in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 22nd, 2016, 05:44 AM
  2. Odd VE table behavior
    By Hib Halverson in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2016, 07:29 PM
  3. Replies: 2
    Last Post: June 28th, 2015, 07:56 AM
  4. Weird behavior tuning and scanning
    By Naf in forum Petrol / Gas
    Last Post: August 6th, 2011, 01:16 PM
