Results 1 to 2 of 2
Thread: 6 speed shift time question
    Aug 2016
    Default 6 speed shift time question
    Hi all,
    I've done a few 4 and 6 speed auto tunes for gas cars, but this is my first time venturing into an Allison. I've been trying to do some research, but it seems like there isn't a ton of info I've found that talks about firming up shifts or reducing shift times with these Allison transmissions. I'm a bit paranoid after reading a couple posts about reducing shift times and destroying the transmission.
    The truck is a 2007 Sierra 2500 classic (older body style) with a Duramax and 6 speed Allison. The stock trans tune is attached below. With a 4L80 or 6L80, or even a 6T40, it's easy enough to shorten shift times and get a crisper shift. Is that okay to do with these? Anything I should be aware of? Any recommendations?
    Any help would be awesome! Thank you!
    2007 A40 stock.ctz
    Oct 2024
    You have a better bet adding a shift kit to the valve body. The Allison is a trans which runs on full line on the 01-10 models they didn't go to a modulated solenoid until 2011 which works similar to a 4L80 and can increase and decrease lie pressure at different operational parameters. You can play with the shift timing some but you have to be extremely careful so you don't have multiple clutch packs applying at the same time. That isn't to say playing with the shift tables and torque model cant get you better results just make very small changes test and see if you get your desired shift feel dot go wild with your changes.
    CALIBRATOR DURAMAX, ALLISON, LS3, L92, 6 Speed Conversions, LB7, LLY, Forced Induction, Speed Density, Mass Airflow.
  1. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
  2. New Shift time tables!!!
    By Rhino79 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 30th, 2012, 01:25 PM
  3. 6l80e shift time completion
    By b18cls1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 14th, 2010, 02:58 PM
  4. Desired Shift Time
    By A6sportsracer in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 27th, 2009, 11:45 AM
  5. Shift Time?
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 9th, 2006, 05:27 AM
