Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Factory Remote start not working after EFI Live tuned
    I was looking for such a solution. Thank you all for your advice.
    Lifetime Member bobo's Avatar
    Nov 2005
    I had to fix this issue recently and found that the grid heater can not be disabled in the ecm. On certain Ram configurations there has to be a diesel preheat process initiated prior to starter engagement. If the grid heater is disabled no matter what OS you use, the remote start may not work.
    Should have left it stock
  1. Replies: 14
    Last Post: June 20th, 2016, 04:53 AM
  2. Remote Start time increases - EFI Live open BCM module???
    By Sparx in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 4th, 2015, 02:35 PM
  3. Efi live and factory fast idle
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2009, 02:50 PM
  4. Pontiac G8 remote start not working
    By KenB in forum E37, E38 & E67 PFI ECM's
    Last Post: February 11th, 2009, 05:14 AM
  5. Can You Use Efi Live to Program Remote Entry?
    By Mitco39 in forum FlashScan V2
    Last Post: January 21st, 2009, 03:28 PM
