Results 1 to 2 of 2
Thread: Unlocking Issue
    Mar 2024
    Default Unlocking Issue
    Wasn't sure where to post this feel free to move it to a more appropriate spot if needed.
    I had a guy with a 04 LB7 that had a locked tune so I got him a used ECM and tuned it/got him squared away.
    Now out of just pure curiosity I wanted to try to unlock it, so I got my bench flash rig all set up on my toolbox and let EFIlive run for 4-5 days(47,000 attempts) trying to unlock it. It seemed to find the Key but when it went to erase the ECM it errored ($0101). So I ran it again for a few days(52,000 attempts) and it got the same error. Then finally thought third time is the charm (only 3100 attempts) it still had the same error.
    Am I doing something wrong or is it a lost cause?
    Picture of the final attempt.
    Attachment 24833
    Lifetime Member bobo's Avatar
    Nov 2005
    https://forum.efilive.com/showthread...Beta-Release-1
    Try the new Beta release.
    {Fixed controller brute-force unlocking which was failing due to extended VIN licensing security. Controllers must now be VIN licensed prior to attempting the range unlocking operation. Affects controllers: E38, E40, E67, LS1B, E54 and E60 only.}
    Should have left it stock
  1. Tune unlocking
    By usafracer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 8th, 2022, 03:49 PM
  2. Unlocking autocal
    By Blackice in forum AutoCal
    Last Post: November 11th, 2016, 09:27 AM
  3. 3rd Gear TCC locking/unlocking issue
    By 1BadAction in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 31st, 2012, 03:41 AM
  4. Unlocking PCM
    By mjp80538 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 02:56 PM
  5. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
